How to keep Bend Part Features suppressed in a base part in a new derived part
micah_k_fitz
Message 1 of 1
micah_k_fitz
Hi, I'm in need of some help or advice with trying to suppress a few Bend Part Features in an iLogic part before deriving this part via an iLogic rule.
To briefly describe my part:
It is a flat plate part that is oblong, with two circular ends that I am utilizing the "Bend Part" feature to bend/form one direction and then bend/form again perpendicular to the first.  I've tried to model this part using the "Sheet Metal" environment and I can only perform one fold/action similar to Bend Part.  I'm assuming Inventor cannot perform complex or compound bends/folds and then be flattened.
To briefly describe my intent:
I want to be able to create a rule that will keep the "Bend Part" features from base part, suppressed in the new derived part.  I have some code that I someone else on the forums had created, which works great if you did not have anything to modify after deriving.  I think I'm going the right direction with code but I'm failing 😞
Thanks in advance
Hear is my snippet of code...
Dim sTemplatePart As String
sTemplatePart = "C:\VaultWork\Documents\Templates\Vessel\Part_template_Vessel.ipt"
doc = ThisDoc.Document
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
oQuestion = MessageBox.Show("Do you want to derive this file?", "iLogic",MessageBoxButtons.YesNo)
If oQuestion = vbNo Then
Return
Else
' Create a new part file to derive the selected part into
' Note: kPartDocumentObject is the default template
' Note: If you want to use a custom template, set the path and filename of sTemplatePart
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, sTemplatePart, True)
Dim sTurnOffBendFeature As Boolean
sTurnOffBendFeature = PartFeature.BendPartFeature.Suppressed(True)
For Each BendPartFeature In ThisDoc
	BendPartFeature = sTurnOffBendFeature
	Next
' Create a derived definition for the selected part
Dim oDerivedPartDef As DerivedPartUniformScaleDef
oDerivedPartDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(ThisDoc.PathAndFileName(True) )
' set the scale to use
oDerivedPartDef.ScaleFactor = 1
''define the mirror plane
''kDerivedPartMirrorPlaneXY = 27393
''kDerivedPartMirrorPlaneYZ = 27394
''kDerivedPartMirrorPlaneXZ = 27395
'oDerivedPartDef.MirrorPlane = 27394
' Create the derived part.
oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
'Copy the iProperties from the assembly to the part
' Save the new derived part.
oPartDoc.SaveAs(path_and_name & "_derived.ipt", False)
oPartDoc.Close
MessageBox.Show("New file created at:" & vbLf & path_and_name & "_derived.ipt", "iLogic")
Replies (0)
