How to iterate through each Part in a Parts Only BOMview?
jake_egley
jake_egley
Basically im making code that will iterate through each part in an assembly get the quantity of the part and then open the part to get a dxf and and area, then take this info and fill out an excel sheet. I've got the parts only bom view set up to give me quantity of each item using a counter. Now I want a for loop that will be something like:
For each Item in oPartsOnlyBOMView
     'open item and make dxf etc. here
Next
But I cant get the syntax right to iterate through each item in the parts only bom view. Can someone please help. This is where im at and I'm using VB:
Dim oBOM As BOM
Dim oDoc As Document
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Set oBOM = oAsmDoc.ComponentDefinition.BOM
' Make sure that the parts only view is enabled.
oBOM.PartsOnlyViewEnabled = True
' Set a reference to the "Parts Only" BOMView
Dim oPartsOnlyBOMView As BOMView
Set oPartsOnlyBOMView = oBOM.BOMViews.Item("Parts Only")
For Each oDoc In oPartsOnlyBOMView
     openDoc = ThisApplication.Documents.Open(oDoc.FullDocumentName, True)
     ThisApplication.ActiveDocument.Close
Next
Jake Egley
Inventor 2022
marcin_otręba
hi,
use  for exporting dxf's from parts only bom view:
Dim oBOM As BOM
Set oPartsOnlyBOMView = oBOM.BOMViews.Item(3)
Dim oBomRow As BOMRow
For Each oBomRow In oPartsOnlyBOMView.BOMRows
Set oDoc = oBomRow.ComponentDefinitions(1).Document
  dxffilename = ""
If oDoc.ComponentDefinition.Type = kSheetMetalComponentDefinitionObject Then
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
Set oSheetMetalCompDef = oDoc.ComponentDefinition
Dim fp As FlatPattern
If oSheetMetalCompDef.HasFlatPattern = False Then
oSheetMetalCompDef.Unfold
oSheetMetalCompDef.FlatPattern.ExitEdit
Set fp = oSheetMetalCompDef.FlatPattern
dxffilename = Replace(oDoc.FullFileName, ".ipt", ".dxf")
Dim oDataIO As DataIO
Set oDataIO = oDoc.ComponentDefinition.DataIO
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=R12&SimplifySplines=true&FeatureProfilesUpLayerCOLOR=255;255;0&InvisibleLayers=IV_BEND;IV_BEND_DOWN;IV_TANGENT;IV_ARC_CENTERS;IV_FEATURE_PROFILES_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ROLL;"
oDataIO.WriteDataToFile sOut, dxffilename
Next
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
jake_egley
Beautiful. Only thing I had to change was this:
by replacing the (3) with ("Parts Only")
Jake Egley
Inventor 2022
marcin_otręba
actually it is the same, you can use name of view or index to get it, where index value is  1-model, 2-structured, parts only
Ideas
or check my apps:
