I have some questions about Vault and iLogic.
Because I made an assembly containing iLogic (1x form, 2x rule). I have processed the parameters in the ipt file. The assembly is set up for use of the frame generator. I made this assembly because it allows us to save a lot of time on engineering. Now I have tested the assembly and it works properly, but now I have started testing it as an assembly in a main assembly. In addition, this assembly must be able to be placed in the mail assembly in several variants. Now I tested this last by copying the main assembly into the VAult (Basic) with the copydesign function. But if after inserting into the main assembly, only the height parameter works. The rest are unresponsive, and at the moment I don't know why this is happening and so I get stuck. hopefully someone can help me on the right track and I can continue with this journey of discovery in iLogic.
The questions I have are:
- What is the best way to handle an assembly with iLogic?
- Is copydesign via Vault the right way to create variable?
- How can I best place it in the main assembly? Because would like to place this as an assembly.
Hopefully someone has an idea how to fix this?
Thank you in advance for the help.
Regards, Joop
