How to I get QTY of Each componemt with Ilogic?
Darkforce_the_ilogic_guy
Advisor Advisor
 I have this code.  I want it to show the total nummmer of each part/assembly  what am I missing or doing wrong?
Class BOMEXport
	Shared Row2 As Integer = 3
	Shared Stk
Sub main()
	PossibleIssueReport()
End Sub
Sub PossibleIssueReport()
Row2 =3
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
oBOM.StructuredViewDelimiter = "."
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Structured")
debug("Call ExportToExcel")
Call ExportToExcel(oBOMView.BOMRows)
End Sub
Public Sub debug(txt As String)
	Trace.WriteLine("NTI : " & txt)
End Sub
Public Function ExportToExcel(brows As BOMRowsEnumerator)
Dim brow As BOMRow
For Each brow In brows
	AssemblyFeature =""
Dim rDoc As Document
rDoc = brow.ComponentDefinitions.Item(1).Document
Dim docPropertySet As PropertySet
docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
Dim docPropertySet1 As PropertySet
docPropertySet1 = rDoc.PropertySets.Item("User Defined Properties")
Dim docPropertySet2 As PropertySet
docPropertySet2 = rDoc.PropertySets.Item("User Defined Properties")
Dim docPropertySet3 As PropertySet
docPropertySet3 = rDoc.PropertySets.Item("User Defined Properties")
'item , part number, qty, description, G_L (Custom), Raw material, Status (Custom)
'debug(" what is the row number now " & Row)
	oHoleRepportExcel = oHoleRepportExcel & docPropertySet.Item("Part Number").Value & "	" & docPropertySet.Item("Description").Value  & " QTY " & docPropertySet3.Item("QTY").Value  & vbLf
Next
MessageBox.Show(oHoleRepportExcel , "Title")
End Function
End Class
SevInventor
have You tried?
brow.ItemQuantity
 For example like this:
        Dim oBOM As BOM
        Dim brow As BOMRow
        For Each brow In oDoc.ComponentDefinition.BOM.BOMViews.Item(1).BOMRows
			QTY = brow.ItemQuantity
			MsgBox(QTY)
			next
Yes that is what I end up using 🙂 fund it 3 days ago 🙂 but Thanks for writte it so I could close this tread 🙂😀
