I have an assembly which configure itself based on a rule. The rule actually suppresses(Visible set to false) some components when switching from one configuration to other.
The problem arises when making a pattern using he assembly.
The suppressed components shows up in all the instances other than the first instance.
The issue of showing the hidden components in the array actually defies the rule set and the purpose of the configuration.
How may I make the components invisible or suppress in the array.
Note: I had made the component invisible using the component occurrence number/name. Since the pattern is dynamic, I have no idea how to do the supression.
Could someone shed some light on this as I am a beginner using ilogic
