How to grab "Base Quantity" with iLogic
Andrew1307
Andrew1307
In the process of implementing an ERP system and need to link the QTY of raw material used in parts to be exported. I have created two custom iProperties, MaterialStockCode & MaterialQTY, that are filled appropriately and then exported along with the BOM. I have my iLogic code that fills these in based on what type of part it is; sheet metal is extents area and outsourced laser cut is by each. Now I am trying to set this up for cut to length parts that come out of the content center, and custom shapes I put into content center. What I am noticing though is not all parts use the same G_L parameter as the Base Quantity.
So instead of trying to link a parameter to my custom MaterialQTY, what I want to do is grab what ever value is being used as "Base Quantity" and put that to MaterialQTY. But how do I grab that? In an inventor BOM its listed as BASE QTY.
rjay75
You're in luck as I just did this not to long ago.
SyntaxEditor Code Snippet
    If ThisDoc.Document.DocumentType = kPartDocumentObject Then
        'See If the BOM Qty has been Overridden. If so use it.
        Dim qType As BOMQuantityTypeEnum
        Dim qQty As Object
        ThisDoc.Document.ComponentDefinition.BOMQuantity.GetBaseQuantity(qType, qQty)
        If qType = BOMQuantityTypeEnum.kParameterBOMQuantity Then
            Dim qParam As Parameter = qQty
            Dim dbUnits As String = uom.GetDatabaseUnitsFromExpression(qParam.Expression, qParam.Units)
            iProperties.Value("Custom","MAT_Qty") = uom.ConvertUnits(qParam.ModelValue, dbUnits, qParam.Units)
Andrew1307
        Dim qQty As Object
Ok so
Gets the base quantity object and stores the values in qType and qQty
 Checks if the type is kParameterBOMQuantity... which means what exactly? If it is left as the defualt each then this would be false?
Here you are grabbing the units and then converting them somehow... I am not at all familar with this. Can you explain to me what is going on here?
Thanks a lot!
rjay75
Yea it could use some more explanation.
'Get the document UnitOfMeasure object to facilitate unit conversions
Dim
uom As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
'Check to be sure we are on a part document
'Initialize a variable for the type and to hold the BOMQuantity Object
Dim qQty As Object
'Get the type and quantity object
'Determine what kind of Quantity type it is
'BOMQuantityTypeEnum.kParameterBOMQuantity : The qQty is the parameter that represents the BOM quantity value.
'BOMQuantityTypeEnum.kEachBOMQuantity : The qQty object is set to Nothing.
'Get the Parameter
'Determine what database units the parameter is set to using the UnitOfMeasure object.
'qParam.ModelValue will be returned in database units, the value needs to be converted to desired output
'units. In this case it's output in the same units as the parameter is set to.
'The iProperty MAT_Qty is set as a numeric value to whatever the converted value is.
Andrew1307
Perfect! Thank you so much.
Further on to this can I use simlar code to set a part to each? ie. I take something from content center but make it a custom part, programically change it to each to line up with ERP.
Also extract what the Base Unit is? (unit of measure)
adam.nagy
Autodesk Support
Autodesk Support
Hi Andrew,
Change Base Quantity to Each:
  Dim doc As PartDocument
  Set doc = ThisApplication.ActiveDocument
  Call doc.ComponentDefinition.BOMQuantity.SetBaseQuantity(kEachBOMQuantity)
Get Base Unit:
  Dim baseUnit As String
  baseUnit = doc.ComponentDefinition.BOMQuantity.BaseUnits
Cheers,
Adam Nagy
Autodesk Platform Services
