how to get Flat pattern is created or not?
How to get whether a flat pattern present in the Sheet metal is proper or unresolved ?
Below is the code I am using
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
Dim sheetmetalcompdef As SheetMetalComponentDefinition
Set sheetmetalcompdef = oCompDef
Dim bHasFlatpatt As Boolean
bHasFlatpatt = sheetmetalcompdef.HasFlatPattern
bHasFlatpatt will return true for unresoved Flat pattern also.
How to get whether it is resolved or unresolved?
Here's the code I use -
If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    MsgBox "The 'Part' must be a Sheet Metal Part"
    Exit Sub
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
Set oSheetMetalCompDef = oPartDoc.ComponentDefinition
If oSheetMetalCompDef.FlatPattern Is Nothing Then
    MsgBox "Create flat pattern and try again"
    Exit Sub
"oSheetMetalCompDef.FlatPattern"  will return object for unresolved Flat pattren also.
When we create a flat pattren even if it is not created, it will return an object and is not "Nothing".
See the attached image for an unresolved Flat pattern icon
Never come across this?
I think I'd be checking how the flat pattern was created.
