how to get document size from iproperties through API
liminma8458
liminma8458
I want to get the size information as in the iproperties of a file (ipt or iam). But I can't find it in object of document.propertysets. How can I get it through Inventor API?
I tried generic VB.NET code such as:
Dim myFile As New FileInfo(Part2.FullFileName)
Dim sizeInBytes As Long = myFile.Length
But the resulted file size is a little different from the one in iproperties. a bit puzzle!
Anyone can help?
Thank you so much!
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
philip1009
What does myFile.Length tell you instead of the iproperty file size, maybe it's giving you kilobits instead of kilobytes?  I'm also curious what you need that info for, if you're at liberty to say.
Sergio.D.Suárez
Dim doc = ThisDoc.Document
oSize = FileLen(doc.FullFileName)
MessageBox.Show("Bytes: " & oSize & vbCrLf & _
				"KB: " & oSize / 1000 & vbCrLf & _
				"MB: " & oSize / 1000000 )
Hi, The following is an ilogic rule, try to execute it.
I hope this helps solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
liminma8458
Oh, I just realize that the little difference is because I used wrong conversion (it should be 1kb = 1024). The result from the generic VB.NET code should be right. Looks like the VB.NET already simple enough.
Our program will create some drawing file (idw) then PDF file automatically. This drawing comes from a shrinkwrap part file. This part is big as tens MB. But I have to save it to disc before I can create a  drawing from it. I have to know the size of the shrinkwrap part so that I can remind designers to delete the part file after the PDF is created. Refer to this thread: https://forums.autodesk.com/t5/inventor-customization/question-on-addbaseview-method/m-p/8803720#M97...
Limin
Sergio.D.Suárez
Why don't you directly delete the created file?
My.Computer.FileSystem.DeleteFile(full file Name)
Mechanical Designer
