How to get correct volume
With Inventor 2013 , user can view iProperties > Physical > Volume. After UPDATE is clicked, the application seems to recalucate and display mass information.  How do I accomplish this task with API? I tried looping through all Occurrence objects, then access MassProperties.Volume, but the numbers do not match what I got from the Inventor application.  The API seems to give me the Volume before the model construction (add parts, extrusions etc.) I need volumes after the final assembly.
Thank you for your help
tuliobarata
Just let me see if i get the point.
U'll need the "net" volume right ?
I'm having some problems trying to get gross and net weights, i guess its the same klind of problem.
With one loop in the ocurrences, i got one problem that IV doesnt open all sub assemblies to put them in the sum, so that just work in the main assy.
Now, if you just want the real volume (with all the features already done), i guess just it should work:
volume = iProperties.Volume
If there is something in common with my problem, follow the link:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/iLogic-How-to-sum-a-property-of-all-su...
Túlio Barata
IV 2013
This will help you..
Sub Vol()
'set odoc as Asembly document or required document
Dim oUOM As UnitsOfMeasure
Set oUOM = ThisApplication.ActiveDocument.UnitsOfMeasure
Dim oMassProps As MassProperties
Set oMassProps = odoc.ComponentDefinition.MassProperties
Dim eLengthUnit As UnitsTypeEnum
eLengthUnit = oUOM.LengthUnits
' Get the equivalent string of the enum value.
Dim sLengthUnit As String
sLengthUnit = oUOM.GetStringFromType(eLengthUnit)
' Create a string that defines a
volume
 using the current length unit.
Dim sVolumeUnit As String
sVolumeUnit = sLengthUnit & "^3"
Debug.Print "Vol  :   "; oMassProps.Volume ; sVolumeUnit
MsgBox ("Vol  :   "& oMassProps.Volume & sVolumeUnit
End Sub
This wil work for you.
Aceept as Solution
