How to get connected element and corresponding connectors
thomas.herrmann2
thomas.herrmann2
Can somebody help me how to get the name of a connected element and the corresponding connectors which are used for this connection?
c#:
foreach (CurrencyAPIv2.IAssetInstance s in objects)
  var c = s.NativeObject as ComponentOccurrence;
I need to know how to find it in IAssetInstance or ComponentOccurrence.
thomas.herrmann2
We solved it with the XML-files which can also be watched in AttributeHelper:
        void LoadConnectors(Document document, List<ConnectionElement> connections, List<ConnectedComponent> components)
            var am = document.AttributeManager;
            var d = new Dictionary<string, string>();
            var entities = am.FindObjects("*", "*");
            foreach (var e in entities)
                try
                    dynamic o = e;
                    foreach (AttributeSet attrS in o.AttributeSets)
                        foreach (Inventor.Attribute a in attrS)
                            d.Add(o.Name, a.Value as string);
                catch(Exception)
            foreach (var element in d)
                XmlDocument xmlDoc = new XmlDocument();
                xmlDoc.LoadXml(element.Value);
                var connectionNodes = xmlDoc.SelectNodes("//ObjectData[@Type='42']");
                var componentNodes = xmlDoc.SelectNodes("//ObjectData[@Type='38']");
                // Verbindungen
                if (connectionNodes.Count > 0)
                    var link1Node = xmlDoc.SelectSingleNode("//ObjectData/Link1") as XmlElement;
                    var link2Node = xmlDoc.SelectSingleNode("//ObjectData/Link2") as XmlElement;
                    var connection = new ConnectionElement();
                    connection.Name = element.Key;
                    connection.Link1 = link1Node.GetAttribute("VAL");
                    connection.Link2 = link2Node.GetAttribute("VAL");
                    connections.Add(connection);
                // Komponenten
                else if (componentNodes.Count > 0)
                    var componentConnectorNodes = xmlDoc.SelectNodes("//ObjectData/Connector");
                    var componentConnectors = new List<ComponentConnector>();
                    foreach (XmlNode cc in componentConnectorNodes)
                        var idNode = cc.SelectSingleNode("Id") as XmlElement;
                        var displayNameNode = cc.SelectSingleNode("DisplayName") as XmlElement;
                        var connector = new ComponentConnector();
                        connector.DisplayName = displayNameNode.GetAttribute("VAL");
                        connector.Id = idNode.GetAttribute("VAL");
                        componentConnectors.Add(connector);
                    if (components.FirstOrDefault(x => x.Name == element.Key) != null)
                        components.FirstOrDefault(x => x.Name == element.Key).Connectors.AddRange(componentConnectors);
                    else
                        var component = new ConnectedComponent();
                        component.Name = element.Key;
                        component.Connectors = new List<ComponentConnector>();
                        component.Connectors.AddRange(componentConnectors);
                        components.Add(component);
