How to get Axis info, Axis ID by Inventor API?
Hi everyone,
To constraint with other object, i want to get information of axis (axis id,...) as below using the Inventor API ?
I checked, but I could only find information of work axis on model tree (BrowserNode).
I would appreciate any ideas/suggestions.
MinhHN.
JamieVJohnson2
That looks like a Revolve Feature, and the axis will be found inside the Feature object.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
@Anonymous : Thank you for responding!
I used the code below to access object Revolve Feature,
but I cannot find the information of the axis, I'm still checking...
PartFeatures prtFeats = oPrtCompDef.Features;
RevolveFeatures revolveFeats = prtFeats.RevolveFeatures;
// revolveFeats.Count = 2
Option InferredTypeEnum.kInferredLine is used to constraint axis of Revolve Feature with axis of other object.
// Add Mate constraint in Assembly
oAsmCompDef.Constraints.AddMateConstraint(face1, face2, 0, InferredTypeEnum.kInferredLine, InferredTypeEnum.kInferredLine);
// Add iMate constraint in Part
oPrtCompDef.iMateDefinitions.AddMateiMateDefinition(face, 0, InferredTypeEnum.kInferredLine);
Thanks for viewing the post.
Minh.HN
