How to get an info on selected part in drawing view using VBA?
Hi all. Hope you guys have nothing on your hands to do, so I can get help pretty soon ... Man Happy
I am trying to make a VBA macro that will, after component is selected (filter for part priority is picked), set component as "transparent" and set line type to "Dash Double Dot". The problem I have is that under SelectionSet.Item(1).ObjectType it says kUnknownObject when component is selected. I was expecting to get info on selected component. Please, see picture below:
I also tried RMB and "Select As Edges", which gives me all selected edges under SeletionSet but I still cannot get info for the component which is the parent for these selected edges. Also, I think, that if I go with "Select As Edges" I will not be able to make component transparent.
What I am missing here? Is it even possible to do this through VBA?
omartin
You can get the occurrence from the edge selection:
Dim dcc As DrawingCurveSegment
Set dcc = ss(1)
Dim dc As DrawingCurve
Set dc = dcc.Parent
Dim face As FaceProxy
Dim edge As EdgeProxy
If dc.ModelGeometry.Type = 67120288 Then
Set edge = dc.ModelGeometry
Set occ = edge.ContainingOccurrence
ElseIf dc.ModelGeometry = 67119520 Then
Set face = dc.ModelGeometry
Set occ = face.ContainingOccurrence
occ.Transparent = True
Was my reply Helpful ? send a Kudos or accept as solution
Hi omartin. Thank you for reply.
This is how I used your code, but it does not work. I am able to change "Transparent" value to true, but on drawing nothing changes.
Public Sub TempSub()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oObject As Object
Set oObject = oDrawDoc.SelectSet.Item(1)
Set dcc = oObject
Set dc = dcc.Parent
Dim occ As Variant
occ.Transparent = False
End Sub
omartin,
I just found out that this "Transparent" vlaue is related to model view and not to the drawing view. It changes transparency for the part in model not in the drawing.
omartin
Hmm. I c, (obviously I didn't test my code).... I think it has to do with drawing views or some where to refresh the view (If I re add the view the transparent will take effect).....
Well You can simply exute the transparent command using this line after the whole part is selected.
ThisApplication.CommandManager.ControlDefinitions("DrawingBodyTransparentCtxCmd").Execute2 (True)
omartin,
Thank you! This will suffice. I totally forgot that I can call commands.
