How to find subassembly's position?
Is there a way to find a position (transform or coordinates) of a subassembly (nested assembly?) into a parent assembly?
For example, I need to figure out where ChildAssembly:1 and ChildAssembly:2 placed into the RootAssembly.
RootAssembly
    ChildAssembly:1
        OneMoreAssembly
            Part1
            Part2
    ChildAssembly:2
        OneMoreAssembly
            Part1
            Part2
I'm not sure if you have a specific point you're looking for on your subassys, but I just used the Origin. I don't know if you're looking for something more but this will give the coordinates of the origin of the specified subassembly
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oDef As ComponentDefinition = oDoc.ComponentDefinition
Dim oPart As ComponentOccurrence = oDef.Occurrences.ItemByName("Assembly2:1") 'AssemblyName Here
Dim oCenter As WorkPoint = oPart.Definition.WorkPoints.Item(1)
Dim oX,oY,oZ As Double
Dim oCenterProxy As WorkPoint
oPart.CreateGeometryProxy(oCenter,oCenterProxy)
'Divide by 2.54 to convert cm to in
oX = Round(oCenterProxy.Point.X/2.54, 3)
oY = Round(oCenterProxy.Point.Y/2.54, 3)
oZ = Round(oCenterProxy.Point.Z/2.54, 3)
MsgBox(oX & " : " & oY & " : " & oZ)
Also, there is a Transform for which one can get data:
AssemblyDocument assembly;
foreach (ComponentOccurrence compOccurence in assembly.ComponentDefinition.Occurrences)
    if (compOccurence.DefinitionDocumentType == DocumentTypeEnum.kAssemblyDocumentObject)
        double[] transform = new double[4 * 4];
        compOccurence.Transformation.GetMatrixData(ref transform);
