How to Extract Countersink/Counterbore Values -- Values Coming Out Null
I am using Inventor 2021. I am trying to detect and capture values from Counterbore/Countersink hole objects.
Does anyone know where these values are stored? I am looking within the HoleFeature object, which contains
CSinkDiameter, CBoreDiameter, etc.
These values are always returning null...anyone know why this is? I have attached a picture of a countersink hole which has obviously non-null values, but I can't find these values in the API.
Any help would be appreciated.
Philip
nmunro
The attached part includes a VBA macro that should get you started. Run the routine from Tools > Macros on the ribbon. The code in the macro is listed below.
Public Sub HoleData()
Dim doc As PartDocument
Set doc = ThisDocument
Dim holeFeat As HoleFeature
For Each holeFeat In doc.ComponentDefinition.Features.HoleFeatures
    If holeFeat.HoleType = kCounterBoreHole Then 'you can check for other hole types with other conditional statements
        Dim holeDia As Parameter ' each numerical value associated with the hole is stored in a model parameter
        Dim cbDia As Parameter
        Dim cbDepth As Parameter
        Set holeDia = holeFeat.HoleDiameter
        Set cbDia = holeFeat.CBoreDiameter
        Set cbDepth = holeFeat.CBoreDepth
        'examine holeDia parameter
        Dim diaValue As Double
        diaValue = holeDia.Value 'internal value stored in cm
        diaValue = doc.UnitsOfMeasure.ConvertUnits(diaValue, UnitsTypeEnum.kDatabaseLengthUnits, UnitsTypeEnum.kInchLengthUnits) ' converted to inches
        Debug.Print holeFeat.Name & " - Diameter = " & diaValue
        ' use similar techniques to examine the other hole parameters
Next holeFeat
https://c3mcad.com
Current update --
I am able to extract most of the cbore and csink holes successfully, however I am still getting an issue with finding the hole center.
This doesn't occur for all holes, just some, and I am not sure why. I have attached a picture showing that I have made a sketch point, upon which a HoleFeature (Hole3) is added.
For whatever reason:
for (int i = 0; i < holeFeat.HoleCenterPoints.Count; i++)
   if (holeSketch.SketchPoints[i + 1].HoleCenter)
      centerPts.Add(holeSketch.SketchPoints[i + 1].Geometry3d);
Does not return true for the hole, and it is skipped.
Does anyone know why this is?
