How to distinguish iPart vs standard part using Apprentice
JeffYao28
JeffYao28
Dear Support or Anyone,
How to distinguish iPart vs standard part using Apprentice 2016, or Inventor API?
Thank you!
Jeff Yao
frederic.vandenplas
In inventor vba, it can be tested like this
In apprentice you'll need to change it to ApprenticeServerDocument
Sub CheckForIpart()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Debug.Print oDoc.ComponentDefinition.IsiPartFactory
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
JeffYao28
Hi Frederic,
Thank you much for the prompt response! I guess I'd appreciate more of  the Apprentice Service method, because it might be faster to open a document. My code is like below:
Inventor.ApprenticeServerDocument objApprenticeServerDocument;
//open the specified file
objApprenticeServerDocument = objapprenticeServerApp.Open(txtFileName.Text);
Inventor.ComponentDefinition definition1 = objApprenticeServerDocument.ComponentDefinition;
But Inventor.ComponentDefinition doesn't have IsiPartFactory property.
My C# project reference to Apprentice is  C:\WINDOWS\assembly\GAC_MSIL\Autodesk.Inventor.Interop\16.0.0.0__d84147f8b4276564\Autodesk.Inventor.Interop.dll
I'd appreciate this "IsiPartFactory" property when I'm opening thousands of part files in batch process to re-organize the documents. I think to open these documents using Inventor API (not Apprentice) can be quite time consuming. But Apprentice seems to be much faster.
Thank you!
Jeff Yao
wayne.brill
Hi Jeff,
You could cast the ComponentDefinition to a PartComponentDefinition and then use the IsiPartFactory property. Below is the code I used to test. I added a button to the form in this SDK sample:
C:\Users\Public\Documents\Autodesk\Inventor 2017\SDK\DeveloperTools\Samples\VCSharp.NET\Standalone Applications\ApprenticeServer\AssemblyTree
(there is no error checking to see that the ApprenticeServerDocument is an ipt)
        private void button1_Click(object sender, EventArgs e)
            Inventor.ApprenticeServerDocument objapprenticeServerDocument;
            string strFileName = @"C:\Users\brillw\Documents\Inventor\WB_2-18-16\iPart_Test_WB.ipt";
            //string strFileName = @"C:\Users\brillw\Documents\Inventor\WB_2-18-16\cylinder.ipt";
            objapprenticeServerDocument = objapprenticeServerApp.Open(strFileName);
            Inventor.PartComponentDefinition prtCompDef = (Inventor.PartComponentDefinition)objapprenticeServerDocument.ComponentDefinition;
            bool bIsIpart = prtCompDef.IsiPartFactory;
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
JeffYao28
Hi Wayne,
Your code worked. Thank you so much!
Jeff Yao
