How to delete an Ilogic part from an Ilogic assembly
Hi everyone,
I hope this topic hasnt been already create.
I'm trying to do a simple task with Ilogic, i made researchs here and on youtube but i did not find the answer....
To make it simple:
I'm looking to delete (inactive?) an Ilogic part from my Ilogic assembly using a command. It's like an option who can be part of the assemby or not ( with option or without option)
In my ILOGIC ASSEMBLY, I went into the Fx parameters , I write a new ''text paramater", using the "Add text".
I named it ''OPTION" and chose 2 texts value for the Equation " WITH" and ''EMPTY" (Empty for without option).
Right after that, I started a new RULES (don't have a name yet so "TEST" will be the name).
Here, I decide to create a rule to active or inactive the part whenever  the option "WITH" or "EMPTY" is set (no option= empty= no part in the assembly=super)
And this is where it stop to work, I don't understand how to procede
Could someone help me please ?
A.Acheson
When your deleting a part you can target the occurrence of the part(unique identifier which index by 1 depending on how many copies of the part you have already in the assembly).
https://forums.autodesk.com/t5/inventor-forum/ilogic-delete-occurence/td-p/3104770
And another with for loops for multiple occurrences by part number.
https://forums.autodesk.com/t5/inventor-customization/ilogic-delete-specific-files/td-p/6551630
Ilogic snippets are a good start in ilogic but sometimes items are missing so you then need to turn to the API help
which comes with your inventor install
https://inventortrenches.blogspot.com/2013/10/?m=0
In here there are multiple examples under samples and then choose category. Or do a target search if you know the name of the operation or object you want to work with  use this with one word searches like occurrence, balloon  or symbols.  Of course you may have to search the internet first to get the correct search phrase for the topic first
Regards
Alan
bhavik4244
@Anonymous
There are 3 ways to do this,
1. By controling the level of detail,
 Make a new level of detail As "iLogic"and activate it and put rule like,
If OPTION= "WITH"
Component.IsActive("ComponentName") = True
Else If OPTION= "EMPTY"
Component.IsActive("ComponentName") = False
2. By controling the visibility of components,
If OPTION= "WITH"
Component.Visible("ComponentName") = True
Component.Visible("ComponentName") = False
3. With use if Begin Mange function, this is a bit tricky but effective way to delete and place part in an assmbly.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Inventor-WhatsNew/files/GUID-80AD0392-0B8C-4A27-A9B3-7466D53999BF-htm.html
Bhavik Suthar
