How to create flat patterns and export them to DXF from assemblies
mindaV3J2J
Message 1 of 11
mindaV3J2J
Hi!
Jus tas the title says, I want to program a way to, firstly, create flat patterns of each part from assemblies, and then export them to dxf. I'm extremely new to the API and dont really know where to start. Can anyone point me in the right direction?
I currently have the following code to connect inventor with the VBA interface.
Dim oDrawing As Inventor.AssemblyDocument
Set oDrawing = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
I've also tried looking at past posts, but many of them have prior knowledge in this area as well. I come from a prior background in python and C++.
Replies (10)
Message 2 of 11
A.Acheson
Hi @mindaV3J2J
Here is an example using ilogic which has VB.NET as the underlining launguage. I used this keyword when doing an internet search
"Export DXF flat pattern from Assembly"
There is many more samples on this forum utilizing ilogic so I would suggest to use that launguage over VBA if your starting out. Knowing each one is also an asset too.
Regards
Alan
Message 3 of 11
mindaV3J2J
Thanks for the help. I've looked at this and several similar ones; however, in the VBA code, I cannot use Dim and set something in the same line, which leads me to believe I'm using a different version than many users here. Is this the case?
The error message is that it expects end of statement.
Message 4 of 11
A.Acheson
Yes for VBA you cannot declare and set the object variable in the same line. So if you likely have ilogic/ VB.Net code which you will need to translate. Please attach the code your using and any error message you have for help in diagnosing the issues.
The alternative is to open the ilogic editor and just paste in  and run the rule from a form or similar.
Regards
Alan
Message 5 of 11
mindaV3J2J
Sub test()
'Set your filepath here:
SETFilePath = "C:\Temp"
'Check for flat pattern >> create one if needed
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.AssemblyDocument
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
'DXF Settings
Dim sOut As String
Dim sPATH As String
sOut = "FLAT PATTERN DXF?AcadVersion=2000&OuterProfileLayer=IV_INTERIOR_PROFILES"
Dim sFname As String
sFname = SETFilePath & "\" & ThisDoc.FileName(False) & ".dxf"
'Export the DXF and fold the model back up
oCompDef.DataIO.WriteDataToFile sOut, sFname
Dim oSMDef As SheetMetalComponentDefinition
oSMDef = oDoc.ComponentDefinition
oSMDef.FlatPattern.ExitEdit
End Sub
This is my current code, I found it from another post and tweaked it a little. The first part where things go wrong are i the first set statement-I've had trouble casting my oDoc variable as an assembly document.
Thanks so much in advance
Message 6 of 11
mindaV3J2J
ive done some messing around with it and heres my new version, issues still remoain
Sub ExportFlatPatternToDXF2()
    Dim SETFilePath As String
    SETFilePath = "PATH"
    If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
        MsgBox "Please open an assembly document.", vbExclamation, "iLogic"
        Exit Sub
    Set oDoc = ThisApplication.ActiveDocument
    Dim oComponent As ComponentOccurrence
    For Each oComponent In oDoc.ComponentDefinition.Occurrences
        On Error Resume Next
        Set oCompDef = oComponent.Definition
        On Error GoTo 0
        If Not oCompDef Is Nothing And oCompDef.Type = kSheetMetalComponentDefinitionObject Then
                oCompDef.Unfold
            Else
                oCompDef.FlatPattern.Edit ->> issue
            Dim sOut As String
            sFname = SETFilePath & "\" & oComponent.Name & ".dxf"
            oCompDef.DataIO.WriteDataToFile sOut, sFname --> issue
            oCompDef.FlatPattern.ExitEdit
    Next oComponent
    MsgBox "Flat patterns exported to " & SETFilePath, vbInformation, "iLogic"
End Sub
Message 7 of 11
A.Acheson
From the API help sample for exporting a dxf from a sheetmetal part
The below is modified accordingly as well as changing from occurrences to all referenced documents. This will make a more universal rule and not be resticted by assembly hierarchy. This macro is untested.
        Exit Sub
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oRefDocs As DocumentsEnumerator =
    Set oAsmDoc.AllReferencedDocuments
    Dim oRefDoc As Document
    For Each oRefDoc In oRefDocs
         'Check if it's a Sheetmetal part:
         If oRefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            Dim oSheetMetDoc As PartDocument
            Set oSheetMetDoc = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
            Set oCompDef = oSheetMetDoc.ComponentDefinition
                oCompDef.Unfold
            Else
            Dim sOut As String
            sFname = SETFilePath & "\" & oSheetMetDoc.DisplayName & ".dxf"
            ' Get the DataIO object.
            Dim oDataIO As DataIO
            Set oDataIO = oCompDef.DataIO
            oDataIO.WriteDataToFile sOut, sFname
    Next oRefDoc
End Sub
Regards
Alan
Message 8 of 11
mindaV3J2J
this got some output!!! However, it failed on the second object when it tried to unfold the second pattern, do you know why this could be? im getting the error message: Mthod 'Unfold' of object 'SheetMetalComponentDefinition' failed
Message 9 of 11
A.Acheson
Can the flatpattern be generated manually? If it can then you need to figure out why it did fail. Is the sheetmetal part read only? If it is then no flatpattern can be generated.
As a last resort on error resume next could be used but it will likely skip the operation entirely.
Regards
Alan
Message 10 of 11
Curtis_Waguespack
@mindaV3J2J How many posts did you make on this topic? Please don't duplicate posts, you ended with multiple people working on the same issue.
See my last reply here:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/turn-off-certain-layers-when-exporti...
Message 11 of 11
mindaV3J2J
Apologies, I couldn't find my original post at one point so I made another. Wont happen again I appreciate it.
