How To Count Circle by Specific Diamter in Drawing
tim11_manhhieu
tim11_manhhieu
I'm trying to count all circle diameter 32.5 to double check.
Below is my minimum code, or if you have better code that would be great.
Option Explicit
Sub CountCircles()
    Dim oDoc As DrawingDocument
    Dim oDrawView As DrawingView
    Set oDoc = ThisApplication.ActiveDocument
    Set oDrawView = oDoc.ActiveSheet.DrawingViews.item(1)
    Dim oCurve As DrawingCurve
    Dim count As Integer
    For Each oCurve In oDrawView.DrawingCurves
        If oCurve.CurveType = kCircleCurve Then
            'HOW TO CALCULATE CIRCLE's DIAMETER
            'If Abs(oSegment.endPoint.x - oSegment.startPoint.x) * 2 = 32.5 Then
                'count = count + 1
            'End If
    Next
MsgBox count
End Sub
tim11_manhhieu
I think I figured it out but there are some problems. Is there something wrong?
1) Why quantity of Φ32.5 is 1126, the right value 1126/2 = 563.
2) but when i count Φ13, the quantity is 10 (this is right value, no need to divide 2)
3) when i changed to Φ31.6, the quantity is zero, the right value is 1.
4) when i changed to Φ32.9, the quantity is double, the right value is 1
(Hole Φ32.9 is concentric with hole Φ31.6 and is on the back side)
Option Explicit
Sub zzzz()
Dim oSheet As sheet
Set oSheet = oDoc.ActiveSheet
Dim oView As DrawingView
Set oView = oSheet.DrawingViews.item("1")
Dim oDrawingCurve As DrawingCurve
Dim diameter As Double
Dim specificDiameter As Double
specificDiameter = 32.5
For Each oDrawingCurve In oView.DrawingCurves
    If oDrawingCurve.CurveType = kCircleCurve Then
        diameter = oDrawingCurve.Segments.item(1).Geometry.Radius * 200
        If diameter = specificDiameter Then
             count = count + 1
Next
Debug.Print count
End Sub
marcin_otręba
hi,
maybe you could post your drawing with model here ? i checked your code with my model and it works fine when i remove doubles decimal length error using:
If Round(diameter, 5) = Round(specificDiameter, 5) Then
in line 28.
in ilogic or vb you can use compareto function:
  If diameter.CompareTo(specificDiameter)=0  Then
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
tim11_manhhieu
Thanks for your enthusiasm,
when I use the software's default template, the result is correct,
but when I use my company's template, the result is wrong.
I don't understand why and I probably don't have the interest to find out why.
Because it's an unnecessary waste of time.
Thanks again.
JelteDeJong
for anyone who finds this interesting. Keep in mind that "oDrawingCurve.Segments.item(1).Geometry.Radius" gives a value in Cm. You need to convert the value yourself to the correct units.
Jelte de Jong
Blog: hjalte.nl - github.com
