how to copy folder containing .idw drawings and rename them with other reference
2020mme013
2020mme013
hi
I have one folder in which there are .idw files and I have to create each files 20 different drawings with other reference number of each. the .idw file should copy the all drawing details instead of keeping the same reference number to its name. I am trying with VBA. please anyone knows about this type of automation help me. Thanks in advance
BM_Ashraf
Not sure if this Add-in the right one for you, but might be helpful in replacing References.
Notice, you can only copy form Part or Assembly not from Drawing.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
2020mme013
hey, Thanks for your reply can you please provide me some piece of code.
BM_Ashraf
Sure,
Here is a similar iLogic Rule.
'This Rule is done By MechDS 28.07.2022
'For Help Please contact me Email: zezo15330@gmail.com
'Youtube
'https://www.youtube.com/MechInventor
'Grab cad
'https://grabcad.com/mech.inventor-1
Dim oDoc As Document = ThisApplication.ActiveEditDocument
Dim oDChack As Boolean = True
Dim oDSuffix As String = ".idw"
'Current file path
Dim oPath As String = System.IO.Path.GetDirectoryName(oDoc.FullDocumentName)
'Get current filename without extension
Dim CurrentFilename As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullDocumentName)
'MsgBox (CurrentFilename)
'Get current path
Dim Path As String = oPath
'Check that the drawing for this part can be found
If Not System.IO.File.Exists(System.IO.Path.ChangeExtension(oDoc.FullDocumentName, oDSuffix)) Then
 	   oDChack = Fasle
	   MessageBox.Show("Couldn't find the Drawing document!" & vbLf & vbLf & "Drawing won't be copied" , "Document Type")
' Prompt user for job number
Dim NewFileName As String = InputBox("You are creating a new copy of this Document and its 2D drawing file" & vbLf & vbLf & _
"Please input a new name for the design" & vbLf & vbLf & _
"Note the current part will be closed and the new one opened...." , "Save As", "")
If NewFileName = "" Then ' Cancel was hit
    Return
oAnsewer = MsgBox("Do you want to save the file to the same Path", MsgBoxStyle.YesNo, "Path")
If oAnsewer = vbNo Then
		'Create new FolderBrowserDialog
		Dim Dialog = New FolderBrowserDialog()
		'Start search path
		Dialog.SelectedPath = oPath
		Dialog.ShowNewFolderButton = True
		Dialog.Description = "Please select a folder"
		' Check Path
		If DialogResult.OK = Dialog.ShowDialog() Then
			Path = Dialog.SelectedPath
 'MessageBox.Show(Path, "PAth")
' Perform Save As of Part
On Error Resume Next
Call oDoc.SaveAs(Path & "\" & NewFileName & ".ipt", False)
'Drawing check
If oDChack = False Then
   Exit Sub
Dim DrawingDoc As DrawingDocument = ThisApplication.Documents.Open(oPath & "\" & CurrentFilename & oDSuffix, False)
' Replace reference to part model
Dim oFD As FileDescriptor
oFD = DrawingDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
Call oFD.ReplaceReference(Path & "\" &NewFileName & ".ipt")
DrawingDoc.Update()
' Perform 'Save As' on the drawing - change this to reflect your drawing type .dwg or .idw
   DrawingDoc.SaveAs(Path & "\" & NewFileName & oDSuffix, False)
' Make the assembly model active again...
oDoc.Activate()
' End of iLogic code ---------------------------------------------------------------------------------------------
Blue Mech
2020mme013
Simply you are genius... Thanks for this AddIn, this is very useful for me.
