how to control if Ilogic rule is triggered based on part type
lingerrobert
lingerrobert
I am looking for help with triggering a rule. i have written a rule that pulls parameters from a sheet metal part. i would like to have this rule run only when the part is sheet metal. Now the rule tries to run even if the part is a standard part. Is there a way to control an external rule to  trigger based on the part type?
Bob
marcin_otręba
You can't trigger depending from file type, but instead just add some condition in first line like:
If part.subtype = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" then
         Your code
end if
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
