How to change to "include this" instead of "match this"?
acadadmin3KNUF
acadadmin3KNUF
Could someone inform me how how to modify this line of iLogic code:
Dim part_to_find As String = "scissors_for_under_21"
I need for this line of code to read "must INCLUDE" this bit of text as opposed to "must MATCH" this.   Thanks for your attention.
acadadmin3KNUF
I'm not entirely sure this is a valid question...it may already be doing it and my code problems lie elsewhere.
ckeveryga
Correct, your issue is somewhere else in the code. That line only creates the string, you need to compare the string elsewhere.
Dim strString As String = "teststring"
If strString.Contains("test") Then
	'Do stuff if string contains "test"
If strString = "test" Then
	'Do stuff if string is "test"
End
 In this code, the first statement is true, but not the second.
