How to change offset value of existing workplane in Assembly
J.VandeMerckt
J.VandeMerckt
Hi Everyone.
I'm trying to write a code which adds a workplane in a assembly.
I can add the workplane but can only use a Double for the offset. (I would like to use a string which references some user parameters.
So my idea was to place the Workplane using Ilogic and change the offset afterwards in the same code and then use the string value.
The Code I'm using to place the Workplane is this:
Sub AddPlanes'Check and add Mid and Back plane if needed
	oDef = ThisDoc.Document.ComponentDefinition
	Dim pOffsetRightplane As String = "pCcLength / 2"
	Dim pOffsetLeftplane As String = "-pCcLength / 2"
	Dim oWPlaneRight As WorkPlane
	Dim oWPlaneLeft As WorkPlane
	oWPlaneRight = AddWorkPlaneInAssemblyOffset(oDef.WorkPlanes("XZ Plane (Right)"), 1)
	oWPlaneRight.Name = "CC Right"
	oWPlaneRight = AddWorkPlaneInAssemblyOffset(oDef.WorkPlanes("XZ Plane (Right)"), -1)
	oWPlaneRight.Name = "CC Left"
	oWPlaneRight.Offset.Expression = pOffsetRightplane
    oWPlaneLeft.OffseI'm t.Expression = pOffsetLeftplane
End Sub
Function AddWorkPlaneInAssemblyOffset(oFace As Object, oOffset As Double) As WorkPlane
	Dim uOM As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
	Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oDef As AssemblyComponentDefinition = oAsm.ComponentDefinition
	Dim oOriginPnt As Point
	Dim oXaxis As UnitVector
	Dim oYaxis As UnitVector
	oOriginPnt = ThisApplication.TransientGeometry.CreatePoint(0#, 0#, 0#)
	oXaxis = ThisApplication.TransientGeometry.CreateUnitVector(1#, 0#, 0#)
	oYaxis = ThisApplication.TransientGeometry.CreateUnitVector(0#, 1#, 0#)
	Dim oPlane As WorkPlane = oDef.WorkPlanes.AddFixed(oOriginPnt, oXaxis, oYaxis)
	oPlane.AutoResize = True
	oDef.Constraints.AddFlushConstraint(oFace, oPlane, uOM.ConvertUnits(oOffset, uOM.LengthUnits, UnitsTypeEnum.kDatabaseLengthUnits))
	oPlane.AutoResize = False
	Return oPlane
End Function
This is the Code which should change the existing offset to my string value but it doesn't work.
	oWPlaneRight.Offset.Expression = pOffsetRightplane    oWPlaneLeft.Offset.Expression = pOffsetLeftplane
 I'm getting this error.
Error on line 50 in rule: CCLength for rails, in document: CAD0006625.iam
Public member 'Offset' on type 'WorkPlane' not found.
I've underlined Line 50.
Can anyone help me with changing the existing value to a string value?
Br
Justin
J.VandeMerckt
Ok so after posting this I realised I needed to change the value of the constraint of the new Workplane.
This is the working Code:
Sub AddPlanes
	Dim oRightConstraint As FlushConstraint
	Dim oLeftConstraint As FlushConstraint
	oWPlaneRight = AddWorkPlaneInAssemblyOffset(oDef.WorkPlanes("XZ Plane (Right)"), 1, oRightConstraint)
	oRightConstraint.Offset.Expression = pOffsetRightplane
	oWPlaneRight = AddWorkPlaneInAssemblyOffset(oDef.WorkPlanes("XZ Plane (Right)"), -1, oLeftConstraint)
	oLeftConstraint.Offset.Expression = pOffsetLeftplane
End Sub
Function AddWorkPlaneInAssemblyOffset(oFace As Object, oOffset As Double,ByRef oConstraint As FlushConstraint) As WorkPlane
	oConstraint = oDef.Constraints.AddFlushConstraint(oFace, oPlane, uOM.ConvertUnits(oOffset, uOM.LengthUnits, UnitsTypeEnum.kDatabaseLengthUnits))
	Return oPlane
End Function
