How to change a specific part item number in Bill of materials using Ilogic
manu.marjanen
Message 1 of 9
manu.marjanen
How to change a specific part item number in Bill of materials using Ilogic?
For example, Now the part (part:1) item number is 10 and i would like it be to something else.
Replies (8)
Message 2 of 9
JhoelForshav
Hi @manu.marjanen
Are you looking for something like this? 🙂
Dim oAsm As AssemblyDocument = ThisDoc.Document
'Pick occurrence to change item number
Dim oOcc As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Pick occurrence")
Dim oBOM As BOM = oAsm.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
Dim oView As BOMView = oBOM.BOMViews.Item(2)
Dim pRow As BOMRow
'find BOM row
For Each oRow As BOMRow In oView.BOMRows
	If oRow.ComponentDefinitions(1) Is oOcc.Definition
		pRow = oRow
		Exit For
Next
If pRow Is Nothing
	'Couldnt find part in structured view. Check Parts only
	oBOM.PartsOnlyViewEnabled = True
	oView = oBOM.BOMViews(3)
			pRow = oRow
			Exit For
	Next
Dim oNum As String = InputBox("Set item number of " & oOcc.Name, "Item number", pRow.ItemNumber)
'If itemnumber already exists, switch the numbers of the parts
	If oRow.ItemNumber = oNum Then oRow.ItemNumber = pRow.ItemNumber
Next
pRow.ItemNumber = oNum
Message 3 of 9
manu.marjanen
Something like this.
For example, If parameter("something") is True  Then Part:1 part number is 10.
Message 4 of 9
JhoelForshav
Is the parameter in the assembly or in the part? Do you want to change the itemnumber in structured or parts only BOM view? What are the conditions and parameter name? Like, if a certain condition is met, the item number should be 10, but what should it be if that condition isn't met?
Message 5 of 9
JhoelForshav
Here's an example if the parameter is in the assembly and its called "itemNum"
It'll change the item number of the occurrence in the assembly called "Part1:1" in structured BOM view if the parameter is True.
Dim oOcc As ComponentOccurrence = oAsm.ComponentDefinition.Occurrences.ItemByName("Part1:1")
Dim pRow As BOMRow
		pRow = oRow
		Exit For
Next
If itemNum Then pRow.ItemNumber = 10
Message 6 of 9
manu.marjanen
This is really good. Thanks a lot
Message 7 of 9
manu.marjanen
I need more help.
If "itemNum" true then "part:1"  item number is what i want. But when "itemNum" is false then "part:1" is not in assembly and thins code give me an error.
Focusing, "itemNum" True "part:1" is in assembly and  "itemNum" False "part:1" is not in assembly.
Message 8 of 9
JhoelForshav
Hi @manu.marjanen
How about this then 🙂
If itemNum
Dim pRow As BOMRow
		pRow = oRow
		Exit For
Next
Message 9 of 9
manu.marjanen
Now work the way i want, thank you 😃
