How to cancel the static value in Vault Revision Table?
zy19860604
zy19860604
I have filled all informations in Vault.
I insert the vault revision table in the drawing.
I found some cells are static value and some cells are not.
How to set which cell is static value and other is not static value?
I want to use  an iLogic rule to change the static value to not.
Thank you for your help.
C_Haines_ENG
There is no "Static" property of a revision table cell, so I don't think this is possible.
