How to Break link from reference files
Hi, I'd like to Break link from derived part or assembly, does anybody have any clue of this, please let me know, thank you in advance.
Is there anybody who can help me with my question, thanks.
The command to do this is contained in the derived part component. It assumes you have a Part document open but could be changed to work with assembly's as well.
{code}
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim part As DerivedPartComponent
Set part = oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1)
part.BreakLinkToFile
{code}
this pulls the first part referenced and breaks its link. you can code it to itterate through all referenece files by replacing the Item(1) with other code and to do assemblies by changing all the DerivedPart's to DerivedAssembly.
Hope this helps.
Thank you very much, this is exactly what I need.
Hi, thanks for your reply, and it did help me. Now I have another question for you. When I create a derived part or assembly, how to mirror it at the same time? thank you.
