how to automaticle add bend notes to a specific drawing view
JonnyPot
JonnyPot
Hello.
I would like to a specific view (A) with all the bend notes automatically made as indicated in the image (like in SolidWorks), and another view with all the bend lines turned off (B)
Thankyou.
bhavik4244
@JonnyPot
To add the Bend Notes:
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oView As DrawingView
Dim oCurve As DrawingCurve
Dim oBendNote As BendNote
oView  = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a View to give the bend notes.")
		For Each oCurve In oView.DrawingCurves
			If (oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendDownEdge _
				Or oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendUpEdge) Then
	oBendNote = oSheet.DrawingNotes.BendNotes.Add(oCurve)
				If oBendNote.Text.Contains("DOWN") Then
					Dim oText = Replace(oBendNote.Text, "DOWN", "DOWN")
					oBendNote.HideValue = True
					oBendNote.Text = oText
				If oBendNote.Text.Contains("UP") Then
					Dim oText = Replace(oBendNote.Text, "UP", "UP")
		Next
To Hide the Bend Lines:
oView  = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a View to hide the bend lines.")
            For Each segment As DrawingCurveSegment In oCurve.Segments
                segment.Visible = False
            Next
Next
Bhavik Suthar
JonnyPot
is it  possible to have them defined to a particular view, it would be very inconvenient to me if i have to select the view every time.
Thank You.
bhavik4244
Try this one:
1. For Bend note:
Dim oViews = oSheet.DrawingViews
'oView  = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a View to give the bend notes.")
For Each oView In oViews
		Next
	Next
2. To Hide the Lines:
	'oView  = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a View to hide the bend lines.")
            Next
Next
Next
Bhavik Suthar
r_pruellage
Hello, thanks for your code. It works very well.
Is it possible to delete the Radius and the Value of it? And delete the ° of Degrees?
