How to automatically find the current project folder(address) with ilogic?
Curtis_Waguespack
Hi MtigaM,
Here's an example.
I hope this helps.
Curtis
Dim IPJ as String
Dim IPJ_Name as String
Dim IPJ_Path as String
Dim FNamePos As Long
'set a reference to the FileLocations object.
IPJ = ThisApplication.FileLocations.FileLocationsFile
'get the location of the last backslash seperator
FNamePos = InStrRev(ThisApplication.FileLocations.FileLocationsFile, "\", -1)
'get the project file name with the file extension
IPJ_Name = Right(IPJ, Len(IPJ) - FNamePos)
'get the project name (without extension)
IPJ_ShortName = Left(IPJ_Name, Len(IPJ_Name) - 4)
'get the path of the folder containing the project file
IPJ_Folder_Location = Left(ThisApplication.FileLocations.FileLocationsFile, Len(IPJ) - Len(IPJ_Name))
MessageBox.Show("Project Name: " & IPJ_ShortName _
& vblf & "Project File Name: " & IPJ_Name _
& vblf & "Project Path: " & IPJ_Folder_Location _
& vblf & "Project Path and File Name: " & ThisApplication.FileLocations.FileLocationsFile _
, "iLogic")
That's really helpful, thanks alot!
one more question:
Is it possible to export the parts list to an excel template with ilogic? : )
Thanks again!
Curtis_Waguespack
Hi MtigaM,
Have a look at these links:
Includes exporting parts list to Excel:
http://inventortrenches.blogspot.com/2011/02/ilogic-code-for-parts-lists-title.html
Focuses on exporting parts list to an Excel template:
http://inventortrenches.blogspot.com/2011/06/ilogic-export-parts-list-with-options.html
I hope this helps.
Curtis
Hi Curtis_Waguespack,
Im using Inventor 2010, and the parts list has to be exported as xls file, but my excel is 2007(xlsx).
Is later version of Inventor able to export parts list to xlsx files?
Thank you!
Curtis_Waguespack
Hi MtigaM,
I don't think your version of Inventor can write out to an *.xlsx file. But you can use an *.xls file with Excel 2007 (it can read or write both). Just open your *.xlsx file and save it as a *.xls and you should be set.
I hope this helps.
Curtis
