how to addin a user-defined form
I have successfully addin a icon in Inventor 7, and I define a form. I want
to click the icon to run the form. When I click the icon, there is a error
that undefined object or with block.
My code is:
Option Explicit
Implements ApplicationAddInServer
Public oApp As Inventor.Application
Public WithEvents oButtonHandler1 As ButtonDefinitionHandler
Private Sub oButtonHandler1_OnClick()
'my defined form
Dia_Pbom.Show
End Sub
You might need to create the form as a new form first before showing it:
dim aForm as new Form1
aForm.show
Hope this helps, can't remember whether you need the "new" statement or not,
but from memory this should work.
"zhao ting" wrote in message
news:968700A9402FF67DF5704EA90BDD843E@in.WebX.maYIadrTaRb...
want
> My code is:
> Option Explicit
> 'my defined form
> Dia_Pbom.Show
> End Sub
J Smith
I am a novice in VB, thank you for your help!
Now I can do the initialization of the form1 in my class module. As follow
code.
Public Sub oButtonHandler1_OnClick()
form1.daihao = oApp.ActiveDocument.PropertySets.Item(3).Item("Part
Number").Value
form1.xinghao =
oApp.ActiveDocument.PropertySets.Item(1).Item("Keywords").Value
form1.mingcheng =
oApp.ActiveDocument.PropertySets.Item(3).Item("Description").Value
form1.Show
End Sub
There is the error if I click command1 button, even though I do it as your
advice.
zhao ting
news:1E8A00A3B115A5F823C336F4D79B18D2@in.WebX.maYIadrTaRb...
> aForm.show
not,
> want
error
> > My code is:
> > Option Explicit
> > 'my defined form
> > Dia_Pbom.Show
> > End Sub
