How to add multiple parts within a loop
The first iteration through this loop adds a part successfully. The next time through gives this error:
"Method 'Add' of object _IRxComponentOccurrences Failed"
For x = 1 To lPartCount
Call oMatrix.SetToRotation(0, _
oTG.CreateVector(0, 0, 0), oTG.CreatePoint(0, 0, 0))
Call oMatrix.SetTranslation(oTG.CreateVector(3, 2, 1))
Dim oOcc As ComponentOccurrence
sPartFileName = "D:/data/parts/Post.ipt"
Set oOcc = oAsmCompDef.Occurrences.Add(sPartFileName, oMatrix)
Next x
I think it's because I'm trying to add a part with the exact same name. Does anyone have examples of adding parts to an assembly drawing within a loop?
tia,
clu
Your code looks ok except I believe each part may
have been placed directly on the previos part.  Here's some code that
places five occurrences in a row in the X direction.
Public Sub CreateAssembly()
Get a reference to the active assembly document.
    Dim oDoc
As AssemblyDocument
    Set oDoc =
ThisApplication.ActiveDocument
Create the matrix that will be used to define the position of the
occurrences.
    ' It is created as an identity matrix which
means the part will be placed in
    ' the assembly in the
same position it exists in the part.
    Dim oMatrix As
Matrix
    Set oMatrix =
ThisApplication.TransientGeometry.CreateMatrix
    ' Initialize the variable that
defines the X position of the transform.
    Dim dX As
Double
    dX = 0
    ' Add a series of
occurrences.
    Dim i As Long
    For i = 1
To 5
        Call
oDoc.ComponentDefinition.Occurrences.Add("C:\Temp\Part.ipt",
oMatrix)
        ' Increment the X position and
modify the X translation portion of the
matrix.
        dX = dX +
10
        oMatrix.Cell(1, 4) =
dX
    Next
End Sub
-Brian
The
Failed"
         Call
        sPartFileName =
        Set oOcc =
    Next x
loop?
tia,
clu
