How to add automatically tolerances to an autmatically created dimesion in 2d drawing by iLogic?
artemijs.nille
artemijs.nille
Hello together,
i am working on drawing automation with iLogic.
At the momenti know how to create a dimension by creating an entities on a 3d modell.
See the code below
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Blatt:1")
Dim Schnittansicht = Sheet_1.DrawingViews.ItemByName("B")
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
Dim AnsaugInnen = Schnittansicht.GetIntent("Sheet Metal (mm):2","AnsaugDKanteDSInnen")
Dim AnsaugDDS = genDims.AddDiameter("AnsaugDDS", Schnittansicht.SheetPoint(1.3, 1.1), AnsaugInnen)
After this code i get the dimension of my diameter.
The value is Ø95
Now i would like to add a tolerance: Ø95 +-1 with iLogic rule to this dimension "AnsaugDDS"
If it is possible it would be great if could explain me how.
Thank you in advace.
Artemijs
Ralf_Krieg
Hello
maybe this?
AnsaugDDS.NativeEntity.Tolerance.SetToSymmetric(1)
R. Krieg
RKW Solutions
www.rkw-solutions.com
artemijs.nille
Thank you very much for a fast reply.
It worked, but currently i have a precision of this tolerance 0,00 so i have Ø95-+1,00.
How can i change it to Ø95-+1?
Ralf_Krieg
Hello
AnsaugDDS.NativeEntity.TolerancePrecision(0)
R. Krieg
RKW Solutions
artemijs.nille
thank you again
i had to change it a little bit that it works:
AnsaugDDS.NativeEntity.TolerancePrecision = 0
