How to access iLogic in Interop.Inventor?
shkangE79NB
shkangE79NB
Hi, I'm creating an addin in c#.
I want to create a program that creates a ribbon button and runs iLogic when it is clicked.
This is my source.
_buttonDefinition.OnExecute += delegate(NameValueMap context)
    var addin = m_inventorApplication.ApplicationAddIns.get_ItemById(AddInClientID);
    iLogicAutomation logic = addin.Automation as iLogicAutomation;
    logic.RunRule(m_inventorApplication.ActiveDocument, "Hello");
In the above source code, addin.Automation is null in line 4.
"Hello" iLogic exists in the document.
Help me!!
Is my method wrong or is there a different way to access iLogic in Inventor 2024?
WCrihfield
Hi @shkangE79NB.  I am not fluent in C#, and I am not an experienced Inventor add-in creator, but the object there are a couple things in your code that might be questionable in my opinion.  First, you may need to use the 'IiLogicAutomation' Type for the variable instead of just 'iLogicAutomation' Type.  However, since I am not fluent in C#, you may need to 'cast' (or convert) the value you get from the iLogic ApplicationAddIn.Automation property to the IiLogicAutomation Type for it to work.  The second thing I would check is the value of your 'AddInClientID' input, to make sure that is the what you would get from the iLogic ApplicationAddIn.ClientId property, not some other ApplicationAddIn.  Not every ApplicationAddIn is going to have a useful value for that ApplicationAddIn.Automation property, but the one for iLogic does, but you must also make sure that the ApplicationAddIn has been activated before trying to use its Automation resources.  Just some initial thoughts.
Wesley Crihfield
(Not an Autodesk Employee)
rjay75
Verify the value of AddinClientID. The call you're making there is to get the addin corresponding to the id passed. If the value on line 4 is null then it means you're not getting the iLogic addin.
The id for iLogic is "{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}".
shkangE79NB
The problem was solved by modifying the clientID.
Thank you!!
