How I can set the item number with ilogic?
I like to set the item names of my parts in my assembly with a ilogic code.
I have an assembly with a part and I know the part number. Now I like to set the item number of this part with ilogic.
like:
part number = Screw22
'(phantasy code)
item.number(" Screw22")=5
and now the item number of the Screw22 is 5.
JhoelForshav
@Anonymous
See example below. You can choose which bom view you want to change the item number in.
Dim oBOM As BOM = ThisAssembly.Document.ComponentDefinition.BOM
For Each oBOMRow As BOMRow In oBOM.BOMViews.Item("Structured").BOMRows
'For Each oBOMRow As BOMRow In oBOM.BOMViews.Item("Parts Only").BOMRows
If oBOMRow.ComponentDefinitions(1).Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "Screw22"
	oBOMRow.ItemNumber = 5
Next
Thanks for the answere.
This looks good for me, but if i try this rule in my assembly i get this error message:
HRESULT: 0x80070057 (E_INVALIDARG)
JhoelForshav
Hi @Anonymous
Maybe the BOM view isn't enabled?
Try this to make sure it is first
'Make sure the views are enabled
oBOM.StructuredViewEnabled = True
oBOM.PartsOnlyViewEnabled = True
Next
it's still not works.
I uploaded a screencast.
But this week I only on my personal computer at home, maybe this can work at my place of work.
JhoelForshav
Hi @Anonymous
Maybe it's a language thing?
Have you tried with the german names for the BOM-views?
For Each oBOMRow As BOMRow In oBOM.BOMViews.Item("Strukturiert").BOMRows
'For Each oBOMRow As BOMRow In oBOM.BOMViews.Item("Nur Bauteile").BOMRows
Next
Check my spelling, It was difficult to read the names due to the resolution of the screencast:)
you are a genius!
with the german names it works perfectly.
Thank you very much
