How extract areas from different surfaces using ilogic
moraesorlando
Message 1 of 14
moraesorlando
Hello folks! My name is Orlando and I am new here and new using ilogic! It is my first post, after spending days reading a lot of posts over here, I continue with an issue unsolved. I would like to say thanks in advance and that I appreciate the help of all colleagues. Here is my doubt: I have a file with several surfaces created by the thicken/offset command. What I need is to extract the area of all these surfaces (separately) and put these values in a form built using ilogic (the form is done and working). I can do this manually using the Measure command, clicking in the surface, copying the value and pasting it in the form. But I want to avoid this manual work. Any colleague can help? Thanks
Replies (13)
Message 2 of 14
fullevent
Hello @moraesorlando and welcome,
is it an iam or ipt?
Can you zip us a pack&go and upload it.
A screencast of the previous manual process is also always helpful for such automation tasks.
Aleksandar Krstic
Produkt- und Projektmanager
Message 3 of 14
moraesorlando
Hello, thanks!
It is a ipt file.
I created a very simplified file and a Power Point with instructions about the manual tasks. Both are attached.
In this simplified file I used just one surface but in the real case I can have up to 10.
In tests I have done, I could see that the sintaxes shown below working correctly but doesn't reach my target because I don't want the total area of the body and my area does not come from a sketch.
(where Area is my variable)
Area = iProperties.Area
Area = Measure.Area("Sketch18")
But
Area = Measure.Area("OffsetSrf1")
doenst work.
If this sintaxe Area = Measure.Area("OffsetSrf1") works. The case would be solved
Best regards,
Message 4 of 14
moraesorlando
Hello @fullevent!
Did my information helps to understand my situation?
Is it possible to help me?
Thanks?
Message 5 of 14
fullevent
Hello @moraesorlando,
I just read your response. I'll see what's possible later today. I'm optimistic about finding a solution here.
regards
Aleksandar Krstic
Message 6 of 14
fullevent
By the way.. do you want to use iLogic with a form (local) or a global form or can it be VBA macro with an userform?
Aleksandar Krstic
Message 7 of 14
fullevent
I already have a first result. Maybe this is a good solution for you. What do you think?
the rule is integrated in the formthe rule is integrated in the formWith a click you can select a surface.With a click you can select a surface.the number equals the area in mm²the number equals the area in mm²is assigned to the user parameter Area_1is assigned to the user parameter Area_1
Attached the file. The value is now also rounded to 3 decimal places.
Aleks
Aleksandar Krstic
Message 8 of 14
moraesorlando
Hello @fullevent!
I just received your messages. Thanks for it.
Answering your question about the forms.
I initiated the idea using the  local form with the ilogic and look like this could be the solution. I haven't tried VBA with the userform.
About your solution,
Yes, this solution sounds very good for me.
I will download the file you sent and study deeply to understand well and try to apply in my real case.
Probably I will be back to you with some new doubts.
Thank you very much for your attention.
Best regards,
Message 9 of 14
fullevent
Glad I could help.
Please mark the post as "Solution" if that is the case after reviewing the ipt.
If there are new challenges, please create a new post with the new question. So everything stays clear and concise.
Until then, have a nice day 😊
Aleksandar Krstic
Message 10 of 14
moraesorlando
Hello @fullevent!
I have studied the code and parameters you built, and look likes clear to me.
But when I tried to insert one more field to calculate area (as I told you in the real case I can have up to 10) the result is not the same.
Steps I used to build the new field for calculate the area:
I created a new parameter named Area_2
I created a new rule (rule 1), copying your code and inside the code I changed the Area _1 for Area_2 (in line 3 and line 5).
I put all in the form.
So, when I test, the result is pretty different.
First difference I have note:
When I click in my button rule 1, the form is disable and an instruction for select a face Is presented.
I select the face, but the instruction to select a face continue been presented to select a face again (not desired).
If I select the same face again, the instruction for select a face disappear and the form became enable again.
Second difference I noted:
If I put any value manually in the field Area_2 (details in the power point attached).
Automatically the rule Rule 1 is started (not desired).
When I use the field you built I don't see any of this issues.
Maybe I forgot to change something in the code or put some parameter in the wrong order?
Attached are the file and a presentation with details.
Thanks again
Message 11 of 14
fullevent
oh yes i forgot to mention that you have to turn off the "automatic mode" of the rule
This will start the rule automatically when a parameter changes.
If you would always select different areas, this rule would start infinitely.
Open the rule1 and set the hooks as shown in the picture.
Have fun 🙂
Aleksandar Krstic
Message 12 of 14
fullevent
By the way, I find that you formulate your request very clearly. This in combination with the screenshots and the ipt file helps a lot to understand and to help you.
Keep it that way @moraesorlando  and you will always get support here very quickly. 👍
Aleksandar Krstic
Message 13 of 14
moraesorlando
Hello @fullevent !!!
Yeah! With this last configuration in “Options” the code is working properly.
Thank you very much for your time and the attention about my case.
Its solved. I will mark the post with " Accepted Solution"
I hope count on your support in other futures posts.
Your support was fundamental for the solution of this case.
Glad to hear your comments about my description of the issue.
I will continue like this.
Best regards,
Message 14 of 14
ivopaulino
Community Visitor
Community Visitor
Thanks for the resolution it will be very helpful, as a part of a solution I'm developing
