how does I get the title and subject properties?
Darkforce_the_ilogic_guy
Advisor Advisor
how do i read the title and Subject like i read desciption in my code ?
Class BOMEXport
Shared oHoleRepportExcel As String
Private oBrowserpane As BrowserPane
	Private AssFeats As New List(Of String)
	Private PartFeats As New List(Of String)
	Shared PartNumberOfParents As String
	Shared PartNumberOfParents2 As String
Sub main()
	Dim docForSubtype = ThisDoc.Document
	Dim sDocumentSubType As String = docForSubtype.SubType
If sDocumentSubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Or sDocumentSubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Or sDocumentSubType = "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}" Then
	MessageBox.Show("files type not supportede", "Title")
Exit Sub
	oHoleRepportExcel =""
	PossibleIssueReport()
End Sub
Sub PossibleIssueReport()
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
oBOM.StructuredViewDelimiter = "."
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Structured")
debug("Call ExportToExcel")
Call ExportToExcel(oBOMView.BOMRows)
'Add To Clipboard(Copy & past fuction)
Clipboard.SetText(oHoleRepportExcel)
End Sub
Public Sub debug(txt As String)
	Trace.WriteLine("NTI : " & txt)
End Sub
Public Function ExportToExcel(brows As BOMRowsEnumerator)
Dim brow As BOMRow
For Each brow In brows
Dim rDoc As Document
rDoc = brow.ComponentDefinitions.Item(1).Document
debug("Error after next")
Dim docPropertySet As PropertySet
docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
Dim docPropertySet1 As PropertySet
docPropertySet1 = rDoc.PropertySets.Item("User Defined Properties")
If Not brow.ChildRows Is Nothing
	If docPropertySet.Item("Document SubType Name").Value <> "Part" Then
Try
Catch
	MsgBox("Fail")
End Try
	oHoleRepportExcel = oHoleRepportExcel & docPropertySet.Item("Part Number").Value &  "	" & docPropertySet.Item("Description").Value &  "	" & "Title"&  "	" & "Subject" &  vbLf
	'Subject
	Call ExportToExcel(brow.ChildRows)
 oHoleRepportExcel = oHoleRepportExcel & docPropertySet.Item("Part Number").Value &  "	" & docPropertySet.Item("Description").Value &  "	" & "Title" &  "	" & "Subject" &  vbLf
Next
End Function
End Class
Frederick_Law
This will write out full list of all iProperties to Info log.
For some reason, some display name and code name are not the same.
Sub Main()
Dim oPropsets As PropertySets
Dim oPropset As PropertySet
Dim oProp As Inventor.Property
Dim oDoc As Document
oDoc = ThisDoc.Document
oPropsets = oDoc.PropertySets
For Each oPropset In oPropsets
	Logger.Info("+" & oPropset.DisplayName)
	Logger.Info("-" & oPropset.Name)
	For Each oProp In oPropset
		Logger.Info(" +" & oProp.DisplayName)
		Logger.Info(" -" & oProp.Name)
	Next
Next
'oPropset = oPropsets.Item("Design Tracking Properties")
'Logger.Info(oPropset.Item("Creation Time").Value.ToString)
'oPropset.Item("Creation Time").Value = Now
End Sub
