How do you open a .htm file within an Inventor VBA prog from a button.
Hi - a real easy question for someone who knows the answer.
How do you open a .htm file and set it as the focused window within an Inventor VBA prog from a button on a userform?
I just want to add a quick help page for a program I've cobbled together.
Thanks in advance for any help anyone can give.
Nik
pball
This is what I was given for opening files before. It will just open the file using the default program on the computer.
        Dim myShell As Object
        Set myShell = CreateObject("WScript.Shell")
        myShell.Run quote(FilePath)
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Thankyou - that is exactly what I was after!
Cheers
Nik
