How do I update my model using VB.net?
JBEDsol
JBEDsol
I'm iterating through a loop changing the plane of a split command but I can't figure out how to update the model each time to check the health status.
WCrihfield
There are several pieces of code for updating a document.
Here are the three most commonly used.
- Each type of Inventor document object has an 'Update' method. (oDoc.Update)
- iLogicVb.DocumentUpdate (iLogic)
- InventorVb.DocumentUpdate (iLogic)
There are also codes that can be activated at the beginning of code that will cause the 'active' document to update once it has finished.
Wesley Crihfield
(Not an Autodesk Employee)
dutt.thakar
@JBEDsol
Another thing you can add to the methods mentioned by @WCrihfield  in this once you end the process is
ThisDoc.Document.Rebuild2 (iLogic) - to rebuild the document.
oDoc.Rebuild2 (VB.Net)
Hope this will help
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
