How do I pass a variable to a VBA sub from within iLogic?
This is a 2 part question
A.  How do I pass a variable to a sub from iLogic
  Ie. I have an iLogic rule that runs when pressing a button
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 1098 StartFragment: 314 EndFragment: 1066 StartSelection: 314 EndSelection: 314
InventorVb.RunMacro("DocumentProject", "basExport2FEMAP", "Export2FEMAP")
However I'd like to have a boolean pass to the sub but I don't know how to do that from the iLogic editor
I have....Public Sub Export2FEMAP()
I'd like....Public Sub Export2FEMAP(blAutoMesh as boolean)
B. once I can pass the bool to the sub can I have 2 buttons run one rule w/ a different boolean for each?  Right now I have a rule for export with automesh and one for just export.  Is there a way of telling the button to change the boolean with just one rule?
Found the answer in this thread
http://forums.autodesk.com/t5/inventor-general-discussion/ilogic/td-p/2611136
Basically I just need to add the variable to the end
InventorVb.RunMacro("DocumentProject", "basExport2FEMAP", "Export2FEMAP",variable1,variable2,etc.)
