How do I make content center remember?
Darkforce_the_ilogic_guy
Advisor Advisor
I have a custom library in content center.... it remember the ones in the blue line for the part , but it chose the one starter set in the content center, as start standard in the red ones ... how is that ? and how if I can ... can it be made to remember them all...?
omartin
Do you mean when you change size?
You have to map your fields to fxParameters (I did a quick test it does not seem like it will work if you try to map them to custom iProperties).
To map the paramters, from the ccEditor, right click on you part -> family properties -> parameter mapping tab -> template paramter tab.
Untitled7.pngYou custom fields should show up in this list.
you can always modify your base part and then re-upload it if you need to create or rename parameters.
Was my reply Helpful ? send a Kudos or accept as solution
Sorry to say that did not do it...that I do is this I change size and place first hole and if I want an extra holes form the other side ... and laste how long form the other side that hole should be.
It remember the the materiel , it remember the profil size , it remember the profil length and it remember if I want an extra hole .. but not there the first hole should be or there the last extra hole should be... it simple reset to content Center standard if change size is made ..so if you want to use anything else you have to remember to type it then you use the change size command
