how do I get the partnumber form the select file ?
Darkforce_the_ilogic_guy
Advisor Advisor
I want to open an file call the "partnumber".pdf ... why does i not get the partnumber form the select part ?
Sub Assambly()
	Dim partnumber
'ask you to select spareparts
	Dim oRefDoc As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select FG component")
setBL(oPart)
End Sub
Sub setBL(oOcc As ComponentOccurrence)
	Try
		MessageBox.Show(iProperties.Value(oOcc.Name, "Project", "Part Number") , "Title")
		partnumber = iProperties.Value(oOcc.Name, "Project", "Part Number")
		MessageBox.Show(partnumber.ToString, "Title")
		InventorVb.DocumentUpdate()
	Catch
		'iLogicVb.RunExternalRule("EditLengthOfOldTypeProfile")
	End Try
	ThisDoc.Launch("\\srv\Prodtegn\_BC365 Varekokumenter\" & partnumber & ".pdf")
End Sub
JhoelForshav
Hi @Darkforce_the_ilogic_guy
Have another look at your code. The variable storing the occurrence is called "oRefDoc", not "oPart".
