How do I get the overridden value from a positional representation??
HermJan.Otterman
Advisor Advisor
HermJan.Otterman
you can override the "relationship-value" with:
oPosrep.SetRelationshipSuppressionOverride(oRelationShip, False)
oPosrep.SetRelationshipValueOverride(oRelationShip, RelationshipValueTypeEnum.kRelationshipOffsetValue, Value)
but is there a way to get this overridden VALUE, once it is overridden?
does it have something to do with the:
RepManager.PositionalRepresentations.ExcelWorkSheet .....??
I can't get anything from this worksheet...
thanks
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
adam.nagy
Autodesk Support
Autodesk Support
You can get it from the relationship object, e.g. the MateConstraint:
Sub PosReps()
  ' The positional representation and the mate constraint need
  ' to be selected in the UI before running this
  Dim oPosRep As PositionalRepresentation
  Set oPosRep = ThisApplication.ActiveDocument.SelectSet(1)
  Dim oMate As MateConstraint
  Set oMate = ThisApplication.ActiveDocument.SelectSet(2)
  posrep.SetRelationshipSuppressionOverride rs, False
  posrep.SetRelationshipValueOverride rs, RelationshipValueTypeEnum.kRelationshipOffsetValue, "12"
  Dim strVal As String
  Dim isOverridden As Boolean
  isOverridden = posrep.IsRelationshipValueOverridden(oMate, RelationshipValueTypeEnum.kRelationshipOffsetValue, strVal)
  Debug.Print "Overridden offset = " + strVal
  Debug.Print "Original offset = " + Str(oMate.Offset.value)
End Sub
Cheers,
Adam Nagy
Autodesk Platform Services
HermJan.Otterman
Thanks Adam,
it worked
I did't know that you cloud get a value this way.
thanks
Herm Jan
