how do I get Curve Loop Lenght into ilogic?
Darkforce_the_ilogic_guy
Advisor Advisor
How do I get the Curve Loop length in ilogoc? I have an profil that alway have 2 feature and 2 Sketch? they are alway call the same .. What I need is the Sketch call "Tooth Belt path"  Curve loop length of the sketch.
Is that a way to do this ?
Michael.Navara
For example see the attached part
'Get sketch with loop
Dim oSketch As Sketch = ThisDoc.Document.ComponentDefinition.Sketches("Tooth Belt path")
Dim loopLength As Double = 0
'Iterate all sketch entities
For Each entity As SketchEntity In oSketch.SketchEntities
	'Skip construction entities
	If entity.Construction Then Continue For
	Try
		'Get entity length when possible
		Dim entityLength As Double
		entityLength = entity.Length
		'Add entity length to loop length
		loopLength = loopLength + entityLength
	Catch
		'Ignore entities without length
		'For eaxample SketchPoint hasn't length
		Continue For
	End Try
Next
'Use result
MsgBox(String.Format("Length of non-construction entities is {0:N2} [cm]", loopLength))
I change the code a lillte , now I just need to find a way to make it only run in the right content center part. but this part of the code seems to work
	Try
	Catch
		Continue For
	End Try
Next
'Use result in mm
 Parameter("G_L") = loopLength * 10
