How do I call verify the login via API Vault Basic
Crstiano
Crstiano
Scenario example:
An assembly is open, but the vault is not logged. Now I want to edit the Assembly File.
Code:
Check if project type = Vault ..ok
Check if user is Logged .. Case NOT !!
What the best path to the Vault, consider whether you need to log in, and then CheckOut?
Today I try with "CommandManager" and execute the "CommandName"
Any ideia??
Cristiano Oliveira
ConsultCAD.com
wayne.brill
This DevBlog post has an example for getting the Vault Add-In connection. (not sure if it works with Vault Basic)
http://adndevblog.typepad.com/manufacturing/2013/09/autocad-2014-vault-add-in-connection.html
These posts could also be helpful:
http://adndevblog.typepad.com/manufacturing/2013/06/checkout-checkin-a-file-in-vault-2014.html
http://adndevblog.typepad.com/manufacturing/2013/06/use-or-with-defaultacquisitionoption-to-download...
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
