How do I add custom properties to a leader text?
Message 1 of 10
I'm trying to basically form a custom balloon that reads properties from a part on a drawing.  Ie.  Part1 has the user iproperty, "System" with a value of "Heating"  Rather than use a balloon (which I also can't seem to get this to read a user iProp) I've tried to add a leader text.
I'm working w/ FDS assets where two identical models can have 2 different iProperties using iLogic. So i can identify 2 identical speakers as "Left" and "Right."
Essentially I want the leader text to read from the part or assy User iProperties like "System", "Circuit", etc.
I can't seem to find any way of doing this.
Replies (9)
Message 2 of 10
CCarreiras
Hi!
Open tool Leader Text, select the part in the view and:
1 - Select the part
2 - Select User Parameters
3 - Select Variable
4 - Insert The parameter
CCarreiras
Message 3 of 10
All that does is insert the value, not a link to the value.  When I update the part the value doesn't update along with it.  Is this because it's an asset?
Message 4 of 10
CCarreiras
In my case, it insert the value... but this value is linked... if it changes, it update.
If you want, post the file here and we can take a look on that.
CCarreiras
Message 5 of 10
Thanks, I'll see if I can mess around w/ some settings and get it to work.
Message 6 of 10
See if this helps
Message 7 of 10
Are you using an asset that can have varying iProperties?  I'm begining to think this is the source of my problems.
Message 8 of 10
CCarreiras
HI!
Is this you want to achieve?
CCarreiras
Message 9 of 10
Yes but I need the value linked.  So far I can only input a static value.
Message 10 of 10
For those looking at this thread, I started a related thread where I think there's more headway to solving the problem.  Thanks all goes to CCarreiras for helping out.
http://forums.autodesk.com/t5/inventor-customization/how-do-i-read-data-from-an-fds-asset-to-a-leade...
