How do change the Maximum Limit of Angle constarint using ILogic
Hi All,
I'm Working on creating Angle constraint by using ILogic. I'm using below functional code to create new Angle constraint. I want to change the maximum limit once the angle constraint got created. Please give your suggestions.
Existing Function code I'm Using now:
oAxis1 = oAsmCompDef.WorkAxes.Item ("Y Axis")
oAxis2 = comp.Definition.WorkAxes("Y Axis")
comp.CreateGeometryProxy(oAxis2, oproxyAxis2)
If Not ConstraintExists(comp, ObjectTypeEnum.kAngleConstraintObject, oproxyAxis2, oAxis1) Then
oAConstraint = oAsmCompDef.Constraints.AddAngleConstraint(oproxyAxis2, oAxis1, 0, 78594)
'78594 refers to the undirected angle constraint solution type. 78593 refers to
'directed (which is default), and 78595 is the referenced vector solution
oAConstraint.ConstraintLimits.MaximumEnabled = True
oAConstraint.ConstraintLimits.Maximum.Expression = "45 deg"
oAConstraint.ConstraintLimits.MinimumEnabled = True
oAConstraint.ConstraintLimits.Minimum.Expression = "0 deg"
If oAConstraint.HealthStatus = oAConstraint.HealthStatus.kInconsistentHealth Then
oAConstraint.Delete
oAxis1 = oAsmCompDef.WorkAxes.Item("Y Axis")
oAxis2 = comp.Definition.WorkAxes("Z Axis")
oAConstraint.Delete
oAxis2 = comp.Definition.WorkAxes("X Axis")
Thanks & Regards,
Manoj Sampath
JaneFan
Hi @Anonymous ,
The way you are using to set constraint limit is correct, would you please describe what error you are meeting using the code?
oAxis2 = oAsmCompDef.WorkAxes("Y Axis")
	oAConstraint = oAsmCompDef.Constraints.AddAngleConstraint(oproxyAxis2, oAxis1, 0,Inventor.AngleConstraintSolutionTypeEnum.kDirectedSolution )
	oAConstraint.Delete
Jane Fan
Inventor/Fusion QA Engineer
@JaneFan
Hi Jane,
I'm not facing any error in this code, Angle constraint creating successfully.
But once the constraint created I want to change the Maximum limit to 0 DEG.
I can change the Maximum Limit to 0 DEG on existing function code, but Inventor taking wrong working Axis and creating Angle constraint, To avoid this first I want to give Maximum limit as 45DEG and I want to change that to
0 DEG once the constraint got created. Is it possible?
Thanks & Regards,
Manoj Sampath
JaneFan
@Anonymous ,
I don't know why it is taking the wrong axis if you set maximum limit to 0 when creating constraint, but it is ok to set constraint limit after creation, as long as making sure the angle value is between minimum limit and maximum limit.
Jane Fan
@JaneFan
Hi Jane,
I have attached the presentation to explain why I don't want to set 0 DEG as maximum limit initially.
Please check and  let me know if you need any Clarifications.
As well as Can you suggest some Functional code to change the Maximum Limit after the constraint creation.
Thanks & Regards,
Manoj Sampath
MjDeck
@Anonymous , please try this code to set the Maximum to 45 and then back to zero:
oAConstraint.ConstraintLimits.MaximumEnabled = False
oAConstraint.ConstraintLimits.Maximum.Expression = "0 deg"
If you can post a sample assembly, we might be able to suggest an easier way to constrain your parts.
In STEP 01 on your pptx, you say that the choke is assembled to the value using "Mate & Insert option". Are you using two separate constraints to do this, or only one?
Mike Deck
Software Developer
Autodesk, Inc.
Hi@MjDeck
The Function code you have provided is working fine.
Thanks & Regards,
Manoj Sampath
