How create a ilogic rule by VBA
I need to add into the current Inventor file (iam, ipt. etc...) an ilogic rule using VBA code and trigger it to a specific event like "before to save the document". I'm looking for an example which I can adapt/modify.
Thanks a lot in advance
Daniele
PS: I know the "Code Injector" application that I used when I have to do that for a mass update, but in this case I need something which my colleagues can simply run with a button.
jdkriek
MegaJerk worked on this for a long time and ended up creating the tool that you mentioned.
His source VB.Net is still available, which I feel would be the best starting point for you.
Adding rules is simple, but applying the event triggers is a diffrent story.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Hi Jonathan,
yes I agree VB.net is better than VBA, but I would like to add this possibility into a macro I already developed by VBA.
I planned to traslate it on VB.Net but I havn't time now, so I'm looking for an example in VBA.
Thanks, Daniele.
dankle43
Daniele,
Did you ever find a way to create an ilogic rule with vba.  I am looking to do the exact same thing that you were looking for.
Thanks, Korey
HermJan.Otterman
also info on the eventtriggers can be found in the source code of MegaJerk.
here is a link
https://forums.autodesk.com/t5/inventor-customization/api-set-an-event-trigger-for-an-ilogic-rule-in...
here is an other one that could help:
http://adndevblog.typepad.com/manufacturing/2015/01/add-external-ilogic-rule-to-event-trigger.html
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
