How can the text height be adjusted with iLogic?
FeelGoodGirl
FeelGoodGirl
Hey everybody,
I made a piece of iLogic code that puts text in a desired place. Only now I want to adjust the size of the text. Below is an example of what I have now and what I want.
Does anyone know how I can do this?
This is my code so far.
Sub Main
	Dim Sheet
	Sheet = "page1:1"
	DeleteNote(Sheet)
	TextX = 5
	TextY = 5
	AddNote(Sheet, TextX, TextY, scale)
End Sub
'-----Deleting note-----
Sub DeleteNote(Sheet)
	oActiveSheet = ThisDrawing.Sheet(Sheet).Sheet
	For Each oGeneralNote In oActiveSheet.DrawingNotes.GeneralNotes
		If oGeneralNote.Rotation = 0.01
			oGeneralNote.Delete
	Next
End Sub 'DeleteNote
'-----Adding note-----
Sub AddNote(Sheet, TextX, TextY, scale)
	' Tekst what is going to be placed
	tekst = "test"
	XPos = TextX
	YPos = TextY
	oNote = oActiveSheet.DrawingNotes.GeneralNotes.AddFitted(ThisApplication.TransientGeometry.CreatePoint2d(XPos, YPos), tekst)
	' When adding the note, it is placed at a small angle. Searching for text at this angle can remove it again.
	With oNote
		.Rotation = 0.01 'radianti
	End With
	oActiveSheet.Update()
End Sub 'AddNote
I look forward to your response.
Justin.B.
Give this a try:
	tekst = "test"
	XPos = TextX
	YPos = TextY
	oNote.FormattedText = "<StyleOverride FontSize='10'>" & tekst & "</StyleOverride>"
You can use the <StyleOverride> tag to change size, font, or set things like bold and underlines, etc.
FeelGoodGirl
This works perfectly. Thank you for your code.
