how can i write from an iam to an embedded excel of an ipt with i-logic
clemens_wolferstetter
I would like to write values from the iam to an embedded Excel in an ipt with an I Logic rule. The ipt is integrated in the iam.
It should work like transferring fx parameters of iam into an ipt with i logic.
Here is the example for fx paramter. I need the same for "GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "A2")"
Sub Main()
Dim Suche As String
Dim zz As Integer
Dim zDa1 As Double
zDa1=KDa1
'Uebertragung der Werte auf das Bauteil:
For zz = 2 To 9
		Suche = "-HMP0" + CStr(zz)
	oDoc=ThisDoc.Document
	Dim oComp As ComponentOccurrence
	For Each oComp In oDoc.ComponentDefinition.Occurrences
		If InStr(oComp.Name, Suche) Then
		oCompName=oComp.Name
			'Fx-Parameter
			Parameter(oCompName, "Da1") = zDa1
	Exit For
	Next
Next
End Sub
Cadkunde.nl
I do the following.
I have user parameters, and fill in the comment "Excel_sheetname_Cell" (for example: Excel_Input_C3)
In my form the done apply/ok buttons are hidden, but I show a button that runs a script.
 Then in my skeleton part i have this script called "Excel Edit"
 It collects all my parameters i wish to bring to excel, then update all parameters and save excel
I add the skeleton part with excel to the assembly (on bom structure reference and visibility off) and name it in the browser #Skeleton
Hello, thanks for the answer.
I would like to bypass the detour of creating the user parameters. I know the parameter number and how to write it in the cells where I want to have it
