How can i Run a Rule in assembly for a other document?
FeelGoodGirl
FeelGoodGirl
I have a composition with different parts. I am looking for a piece of code with which I can run a rule in one of the parts. In the image below I have drawn what I mean.
So I am looking for a piece of code to put in the assembly, to run the rule in block 1.
After some searching work I found the piece of code below. But I can't get this to work.
iLogicAuto.RunRule(oDoc, "RuleName")
blandb
In the snippets, go to Run Other > Run Rule:
iLogicVb.RunRule("ruleName")
Is this what you are looking for?
Autodesk Certified Professional
mcgyvr
Slightly more specific
iLogicVb.RunRule("block 1:1","Rule_Name")
blandb
Oops, yes...copied wrong line...sorry 🙂
FeelGoodGirl
SUPER, this was exactly what I meant! 😄
I did not realize that I could use the name in the assembly. Had already tried with the path of the file, but without success.
