How can I mirror a body/feature by iLogic rule ?
Hi everyone,
I'm encountering a problem with the part mirror feature on iLogic.
oTO is TransientObjects
oBds is oDef.SurfaceBodies
oMirrs is oFeatures.MirrorFeatures
I also precise that there is only 1 solid in my part
Here is my code :
Dim ObjectsACopier As ObjectCollection = oTO.CreateObjectCollection
    ObjectsACopier.Add(oBds(1))
Dim MirrDef As MirrorFeatureDefinition = oMirrs.CreateDefinition(ObjectsACopier, oDef.WorkPlanes(2))
Dim CadreOp as MirrorFeature = oMirrs.AddByDefinition(MirrDef)
Which give me this error :
"Erreur non spécifiée (Exception de HRESULT : 0x80004005 (E_FAIL))"
Can someone explain me where is my mistake ?
If I'm precise enough, tell me.. i can give more info.
Windows 7
Inventor 2018
JamieVJohnson2
E-Fail means bad command input, or inappropriate time to run command.  Because that means MANY things, and your code is out of context, you need to make sure the input is good first.  You are going to have to stop the code and verify the input, use msgbox("text") to stop the code, and put in the text something to help you identify and validate.  If the input is good, verify you are using the command correctly (giving it a rock, when it asks for a fruit), and at the right time (mirroring a feature while a drawing document is active).
Windows 7
Inventor 2018
the input.  Or use Visual Studio to run and step through you code and view values on the Local's window (but it has to be pure .Net code, so some iLogic may not directly translate).
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
