How can I make selected the part or sub from API?
mucip
mucip
I'm using Inventor 2013 and VB 2010 Express... I can find a part or sub from browser and open it seperately by below code:
 Dim invDocs As AssemblyDocument
        invDocs = Form1.inv_App.ActiveDocument
        Dim invDocument As Document
        Dim Sayac As Integer
        Dim oRefDocs As DocumentsEnumerator
        oRefDocs = invDocs.AllReferencedDocuments
        Dim invDocument2 As Documents
        invDocument2 = Form1.inv_App.Documents
For Each invDocument In oRefDocs
            If Form1.BaseFilename(invDocument.FullDocumentName).ToUpper = TextAranan.Text Then  invDocument2.Open(invDocument.FullDocumentName, True)
            Sayac += 1
Next
But I need to make the part selected on the browser? I want to focus (highlight) on the part and reposition the browser tree?
Is this possible from API?...
Mucip:)
xiaodong_liang
Autodesk Support
Autodesk Support
get the active BrowserPane, next BrowserPane.GetBrowserNodeFromObject to get the browser node that corresponds to the input object. Finally, call BrowserNode.DoSelect
mucip
First of all thanks a lot for your kind interest...
I couldn't understand very well. Please could you explain little bit more detailed?...
Mucip:)
mucip
I found something after than your guidence e-mail.
Below code is working good but only for the first level of the tree. I need to iterate/search all levels of the assembly tree.
How can I do that?...
        Dim bp As BrowserPane
        Dim nodes1 As BrowserNodesEnumerator
        bp = invDocs.BrowserPanes("Model")
        nodes1 = bp.TopNode.BrowserNodes
        Dim node As BrowserNode
        For Each node In nodes1
            If node.BrowserNodeDefinition.Label.Split(":")(0) = TextSearchFileName.Text Then
                node.DoSelect()
                Exit For
        Next
Mucip:)
mucip
Any feedback incase of search all levels of the model tree?...
Mucip:)
